Here is some pics of the Intelliview Plus 2 color touch screen that I was running tonite.
Now that looks nice. I see your in "Run1". What do the other 4 do? More monitors? Alot more info on the screen then what I see in the 940. Only 5 I see. Plus the rotor, seive and return loss. Any pictures of the combine?
That is the same system that the 7010/8010 CIH combines have been using. I also recently heard that the CR's got the hydraulic drive cleaning fan system as well that the 8010 has had since 2003.
What are you harvesting? My guess is canola. Can you run them that slow? We've been running ours more up a 700-800. I'll maybe give it a go slowing everything down. How was the crop overall?
There are 6 "Run screens" and can have 12 box's showing just about anything you want to see. Or can have 1 box as in Run 3 is set up to show mapping if you are tring to field map.
580-590 is top speed in low range on gearbox. Most of the canola is 25-30 b/a. Some 35-40 temps at late flower to early pod probably cost 10-15 b/a.
Takes forever to put a wad through at that speed doesnt it. Thats the reason I run it a little higher.
But then if you dont have a rookie swather operator, it shouldnt be that much of a problem.
