My relatives run 580r lexions and they demoed a 9230. Their claim was taking off their 7000 acres. a 9230 would be using $40,000 more diesel. They run red except for the combines. thats almost $6 an acre.
Which gallon?My CR9080 was burning about 1.5 gallons per acre in 80 bushel winter wheat with a broken silicone ATA coupler. After that was fixed it was down to .8 to 1 gallon per acre.
Indeed.I guess that lexionsmust not use any fuel at all to make a statement like that. We ran a 9230 this year and our fuel usage was a between 5 and 6 liters per acre. I really don't know how they can make a statement like that without someone calling
B.S.
US gallon. Meant to convert that before posting but i have turkey brain the past few days.Which gallon?
Am I reading this right, the bigger combine is burning less fuel while getting more done??? What is the difference? rotors? engine?.....I run a Cr9060 and a 9070. the 9060 has a 200g tank and the 9070 has a 250 if im not mistaken. Running in 36 feet of canola the 9060 is on the red by the end of the day and the 9070 will likely not be at 1/2 yet while getting i would guess 20% more done or better. I havent figured out the fuel cost per acre but it isnt rocket science to see the difference is huge.
2 years ago I ran an 8120, conditions were tough with ( mega cut chopper? The one better than the fine cut) but we were 3.5 gallons per acre in wheat, I had rented the combine from my father inlaw and it became cheaper to hire guys with trucks and grain carts and operators, even poped in a stienbouer and no diff we could tell, what a pig on fuel, around 1.3 gal in beans, and 2.25 in corn with a knive roll head so in them crops it wasn't so badI guess that lexionsmust not use any fuel at all to make a statement like that. We ran a 9230 this year and our fuel usage was a between 5 and 6 liters per acre. I really don't know how they can make a statement like that without someone calling
B.S.
There was something wrong with that combine! I did lots of checking this fall and my 9230's were between 5 and 6 liters/acre(that's about 1.5 US gpa) so I would totally agree with sasksodbuster on this. Late harvest this year and tougher than normal conditions too.2 years ago I ran an 8120, conditions were tough with ( mega cut chopper? The one better than the fine cut) but we were 3.5 gallons per acre in wheat, I had rented the combine from my father inlaw and it became cheaper to hire guys with trucks and grain carts and operators, even poped in a stienbouer and no diff we could tell, what a pig on fuel, around 1.3 gal in beans, and 2.25 in corn with a knive roll head so in them crops it wasn't so bad
I have magna-cut too and knives are always up. Something's just not right about those numbers. Unless you were going 1.5 mph in soaking wet straw??? I have never seen fuel use double from normal like that although 20 series burnt slightly more fuel per acre of work.I think it just goes to show how much power a good chopper and green straw can burn up, like I say when we drop the knives I believe it is average fuel in corn and beans, with corn being higher due to only running an 8 row on it. I am a mechanic by trade. Attended NDSCS, combine run fine
The engine is the biggest difference 9060 is 9L and 9070 is 10.3L. Working the little engine too hard makes it burn a lot of fuel. If you get the 10.3 turned up a little you can find the limits of combine.........Am I reading this right, the bigger combine is burning less fuel while getting more done??? What is the difference? rotors? engine?.....![]()
What kinda claim is this without actual fuel meter filling. We have all had vehicles and equipment that the top of the tank on the gauge lasted forever and the bottom half was gone in a couple of hours. With two different tank designs you can't go by fuel gauge and call is science .I run a Cr9060 and a 9070. the 9060 has a 200g tank and the 9070 has a 250 if im not mistaken. Running in 36 feet of canola the 9060 is on the red by the end of the day and the 9070 will likely not be at 1/2 yet while getting i would guess 20% more done or better. I havent figured out the fuel cost per acre but it isnt rocket science to see the difference is huge.
