We plummed ours into the real hyd. The spreader will only run when the head is on, is the only drawback. Not alot of work, just put a tee in before the plug in.
I have a Crary single disk chaff spreader for my T98 combine. How do you plum it into the hyd system? I cant use my header hyd outlets because I have a swathmaster pickup with hyd lift and the pump uses hydrolics on it. Do I need to tee in somewhere else? Any sugestions or pictures would be great. I am hoping I can find a threaded line and get a threaded tee so I am not cutting and crimping. TIA
