21 - 40 of 184 Posts
Discussion Starter #24
Hello
Thank you for the comment.
Realization on the pickup, of the pulleys, Cardan joint and various axes
To go with MF 510, there was a andaineuse reaper has carpet on dimensioned with pickup cutting width 3700, it had been imported the USA in 1960, the training was by Cardan joint, of large wheels has tires and of the wheels of transport on the sides
If you have photographs or documents on standard of machine, I am interested
Thank you
Discussion Starter #25
Hello
Thank you
Discussion Starter #27
Hello
I do not know if that interests you, but here some photographs of work on the pickup
realization has to come at the 1/32 from Massey Harris 21
:47::47::47:
Discussion Starter #28
Hello
Completion of the pickup of MF 510
Beginning of construction of the MH 21
Discussion Starter #29
Hello has all.
In the family there was also Massey Harris 21 of 1945
Here beginnings of the construction of the MH 21. If you have documents has to pass to me I am interested,
You can leave a comment if you wish it
Thank you very much
Discussion Starter #30
Hello
Advance of the MH 21,
Drum of in grainage, beater, drum of release, against beater, chimney of cooling, driving support/radiator/chimney has slide, etc.
With more for those which that interests
Discussion Starter #32
Hello
Thank you for your comments
Here the Chrysler engine six cylinders of the MH 21
If somebody little to inform me about the radiator
Between do the engine and the radiator have to you it there a careenage so that the propeller of the ventilator aspires the air in the chimney of the machine?
As on the reproduction
Thank you
Discussion Starter #33
Hello.
For the people that interests.
Work on the rear wheel-axle unit, remade twice, maintaining that holds.
With more
Discussion Starter #34 (Edited)
Hello
Small work on the engine of the MH 21.
With more can be? not having messages it is that does not interest high society.
Goodbye
Discussion Starter #35
Hello
For those which that does interest?
Rravail on the engine
realization of the vat has dust back
Not having plans or dimensions (simply on photographs, presentation of a gauge (paper) of the conveyor.
With next can be?
Discussion Starter #36
Hello
Work on the screening machine of grain, in manufacturing and cementing
then poses on the machine with realization of various pulleys
To make thereafter the gear box/differential/brake, the punt forms of control and bagging.
goodbye
Discussion Starter #37
Hello some small work on the threshing-machine
Shakers, the tank of petrol, the protection of the pulleys, etc.
For the people who to follow the topic
With mor
Discussion Starter #38
Hello and goodbye
Apparently not much of comments, it is that should not you like that, therefore
Good-byes, I turn over to France
Discussion Starter #39
Hello Quappelle
Here some photographs of my work on the MH 21, I see that does not impassion many people, but there are some people who look at, unfortunately they do not put messages, and I do not know if what I do is correct.
it in painting, a question, is what the rims of the wheels are yellow or gray. ?
I must make a andaineuse reaper Massey Harris n° 7 to go with the 510, would have plans of them, or photographs because I do not have large thing
Thank you has you
Bernard
