I removed the intercooler to clean it. I taped up the inlet and outlet, then cleaned it with a hot water pressure cleaner. The hot water heated the whole thing up and the air inside expanded, but had nowhere to go as the inlet and outlet were taped up.
I noticed small bubbles of air escaping from the join between the side tank and the base frame at the place circled on the attached photo.
From what I can see, it is only welded around the outside, and not on the inside corner, so there is no way that it can be air tight.
So, do all John Deere CTS-2 intercoolers leak at this spot? Maybe other models/other brands do as well?
The machine runs fine and has enough power, so I am not going to replace it.
When the engine is running, if it leaks, it shouldn't be sucking dust into it, as it is pressurised. But what about when the engine is stopped and you are blowing out the radiator with an air gun?
Just wondering if they are all like it? Just badly made?
