The reel drive hydraulic pump shaft failed on our CTS-2. The end of the shaft broke away where the groove for the circlip goes. This allowed the shaft to slide out of the bearings causing the pump to come out of place and run its belt off.
Unable to find anything that would have caused this to happen. The bearings were okay, all the other pulleys on the same belt seem fine.
Anybody else had it happen? Is it common? Seems like only having a circlip to hold it together is a bit flimsy? Is it just a bad design?
