Ooohhh Deere
Dumb question but have you checked the oil level?? It nay have done a seal on a hyd pump and has pumped more oil in there overfilling it
Anyone have trouble with the engine gear box overheating on a cx8080? Just starting getting hot today all of a sudden. It heats up and give the code to stop because of overtemp.
I think that is the issue when looking at it closer in the daylight this am. It is over full. So like u say Prly a deal
Ooohhh Deere
Dip it 2 or 3 times as the tube gets air locks in it.
if overfull drain some out to operating level and keep going. Monitor the level and you may be able to finish harvest or you may have to reseal a pump on a rainy day.
But as others have said, it may just be the temp sensor packing it in. Heat gun the same spot as the sensor if possible and see if the cab display reading is similar to the heat gun.
