1 - 1 of 1 Posts
Does anyone know if there is a repair for the deflector plate motor/drive on a turbo chop straw spreader. They don't seem to last and it is $1088 dollars for that little jewel, which only controls one of the deflectors. Part of the problem is that they cycle to zero deflection everytime the seperator is turned off and then move to where you have it set when engaged. The area under the shield where the drives sit fill up so fast with debris that you can't keep clean and jam mechansim. For now I will say no thank you for spending that much on something doomed to fail again.
1 - 1 of 1 Posts
