1 - 9 of 9 Posts
Discussion Starter · #4 · (Edited)
How fast do you guys go on the road with those tractors? This one has 278 hours in wet conditions and so far none have delaminated. I only move the drill at 14 MPH maximum though.
This year maybe 8mph as the roads are so destroyed. It's like the mud hydraulically pressed the rubber clean off the roller.
Talked to my guys they said hutts had trouble with 9rx doing same thing, they were roading the drill at high speed. Both have camso track systems iirc.
What does A new mid roller cost and can you run it without the rubber on or will it destroy the track?
1120$ for new mid roller. 475$ and 7-10 days for recap at fort garry rubber.
You can run it without rubber in the mud and water. Have to go slow on the road as it will heat up quicker, and on hard ground it isn't great as the bogeys are uneven side to side. Not sure how much it matters on versatile with pivoting midrollers.
1 - 9 of 9 Posts
