1 - 20 of 23 Posts
I realize thst a 6088 has the 8.3L and the 7088 has a 8.9L. Are there any other differences (besides numbering) between a 6088 & 7088?
I am under the assumption that I could chip a 6088 and basically have a 7088 at lower cost. I know the price difference between a 7088 and 6088 is greater than the cost difference of the engine, but I am attributing that to CaseIH marketing to help improve their profit margin.
Please correct me if i am wrong and I look forward to your responses....
Striker782 correct me if I am wrong but, I think the 5088 has a 2.25 inch rotor belt and the 60 and 7088 have the 3 inch belt so I think the break is in between the 50 and 60-70, I hate to disagree with a fellow husker
Discussion Starter · #12 ·
Getting back to my original question...
Assuming Sliver & I are correct and the only difference between the two is the engine, then would 6088+chip = an unchipped 7088? Even at the 15% level on a chip the 6088 should produce more horsepower than a stock 7088 (even after rise and boost) and still have all the other components of a 7088 without the added cost.
There are different chips out there some you have a choice anywhere between 10% and 30%
some are fixed. One thing to check is your cooling are the two machines the same, more power means more heat make sure you can get rid of it. I have a chipwith 2 settings on a 7710 John Deere tractor had it on a dyno this spring maxed out at 225hp I don't use that setting because of the heat created it blows out exhaust manifold gaskets
So there is only 20 Hp difference between the 2? This dosen't seem like enough of a gap to warrant having 2 near identical models only 20 Hp appart
I work it out to be 45hp difference with unload boost
Apart from the engine size and hp difference I believe the specification is exactly the same as the 6088. List price difference is approx. $25K
The 7088 is a new "class" size header in the 88 series that has not previously been offered.
1 - 20 of 23 Posts
