Hey dutchengineer... This isn't a soy question obviously, but is there a way with the Universal body to put nh3 in a sideband? Thinking of using the drill to put seed and phos down the granular tube at seeding. Then in the fall, run K+S down the granular tube and nh3 out the sideband. Looking for ideas on going to NKS in the fall without changing/costing too much.
Andrew
Apologies for taking so long to respond.
Hi Andrew,
To answer your question, sidebanding NH3 with Universals is not something that has been done at this time; however, there are a couple of options that could address your request.
Using the rear delivery NH3 tube on Universal you could use a 3/4" deep sideband tip to place the NH3 in the middle and dry or liquid fert to the side.
How important is it to keep separate the NH3 from the dry fertilizer?
A better option might be our Universal for Fertilizer Series. This system has the ability to place NH3 and dry or liquid in a single row. As with the rear delivery Universal, there are 3/4", 1", 3", 4" and 5 1/2" tips to select the soil disturbance you want. You would have to install the no-freeze tube and may have to change tips to accomplish this.
I can get you more info on each of these if you are interested.
We have farmers in North Dakota who run this system successfully for fall fertilizer using NH3 and Granular and NH3 and liquid (TAPPS actually)
Do you have a lot of the universals in Manitoba with the side band? Are they using fertilizer? What products and rates?
Hi Wetfarmer,
The Universal Sideband has a fair size following in Manitoba. Most sideband customers would be using dry or liquid fertilizer. Rates depend a lot on the operation and the area. We suggest you talk to your agronomist about your situation (soil type, growing season rainfall, crops).
We have customers who successfully applied over 100 lb/acre of actual N. This has also been used with soybeans to sideband fertilizer.
I am curious about the situation with the Dutch Paired Row you have sown the soybeans with the last two seasons. What type of drill is it? What opener are you running? Are you putting the beans in a paired row or are you using the single row tube on a triple shoot tube?
D.E.
