I think there will always be a market for a 35' 2020 (the thing I never liked about the 2020 is the way the field tracker works with it).....as long as they fit on a 7010 and a 8010. I walked around a new 40' 2162, they are a beast, the feeder belt looks to be over 6'wide. MacDon has made some changes to the new drapers.....they are supposed to be easier to set up, keep in adjustment, and feed better. The drapers do take a little bit of getting used to and a good mechanic to set them up right. I'm not sure how they'd run in wet ground. With a 40' head you'd need the long unload tube. If you want the biggest, go for the 2162.
