Re: early sts owners-fast and cheap way to fix int
Check this to see if it will help you.
Solution Number: 45314
Solution Summary: ENGINE AIR INTAKE SYSTEM PROBLEMS / FILTERS PLUG / EXCESSIVE EXHAUST SMOKE / ENGINE RUNS HOT / LOW POWER / SIBS H89-5-25-4 and H89-5-25-5----- All Combines
Publication Date: Jan 28 2003
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom:
The engine air intake system has a problem. It may show up as any of the following complaints:
Plugged filters or dirty filters
Air restriction light comes on
Low power
Excessive exhaust smoke
Solution:
FILTER HOUSING AND TUBES
Visually inspect the air filter housing for leak points. Does the lid fit tight? Are there gaps where the tubes fit together? These joints will be somewhat loose, they are not totally air tight by design. On 10 and 50 series combines, are there any cracks in these plastic parts?
FILTERS
If the primary ( outside ) filter is plugged and dirty in a specific area, this can indicate a leak in the filter housing. Refer to the operator's manual for complete instructions on inspecting the filters with a light. Wash these filters as instructed in the manual. If compressed air is used, always blow air from the inside out. Sooty filters indicate an exhaust system leak. Also see solution 6145.
ASPIRATOR
Be sure the check valve is not stuck. Inspect the hose to be sure that it is tight and that it is not kinked, cracked or collapsed. Is the muffler worn out? Any of these problems with the aspirator will cause the filters to get dirty prematurely.
LOW ENGINE POWER AND / OR EXCESSIVE BLACK EXHAUST SMOKE
Any problem with the air intake system may result in low power and / or smoke. Also consider bad injectors, pump out of time, low turbo boost, engine fan on backwards, low cetane fuel or a hole in the intercooler. Also see solutions 5142, 6028 and 6295.
