1 - 2 of 2 Posts
Tried to hook header tilt wire for Macdon header on 9770. Now got electrical issues. Unloading auger won't swing, reel fore and aft makes reel lift, header stays engaged with switch off but reel doesn't turn...
Are you talking about the fore/aft pitch control wire?? normally that would go to an added switch in the cab, hooked to the power strip.
I can't imagine what you did to get the above symptoms. The first thing I would do is hook on a different head and make sure the combine works there...if not you fried a controller or something.
1 - 2 of 2 Posts
