1 - 14 of 14 Posts
NH SP240F sprayer with Raven Envizio from factory. Dealer added Trimble auto steer with FM750. Guidance works as it should but now the Raven will loose GPS when you Start moving. Tried getting GPS to the Raven from the FM750 and from the Nav controller and both had the same results. Can spray manually but can't use the accuboom feature for automatic shut off.
What am I missing to make this work?
What settings are you using to output GPS. NEMA Strings? Baud Rate? ETC... Since the Envizo is not hooked up to raven autosteer it should work just fine.
Also one thisng to keep in mind is if you are using sectional control on the Envizio and are taking GPS from the nav that the nav signal is already corrected for offset measurements.
Antenna to Axle Off set, Antenna Height ETC...
So when you are setting up you off set measurement for the sectional control on the envizio take that into account.
No DGPS
Envizio says Accuboom node not detected. Where is it located? I see the single product node and boom speed node. I'm not sure if all the hardware is in place for accuboom.
The accuboom node is there it wasn't detected with the switch on, the engine had to be running. I had 10-12 satellites showing on both the FM 750 and the Envizio. The Envizio is not showing DGPS. The NMEA settings are, GSA 10hz, GSV(?) 10hz, ZDA 5hz. Baud rate 19200.
Is DGPS needed for accuboom ?
1 - 14 of 14 Posts
