I have a 1993 9600 combine and it has started showing an error code of 44e. The engine has also started to run rough. We changed fuel filters, but the problem has persisted. We also changed the secondary engine speed sensor, but no luck. I am told there is a primary speed sensor in the injector pump, but the dealer will need to change that.
I am also getting 37 e error.
Anyone ever deal with these codes and figure out what was causing the problem?
