9500 combine having intermittent issues. Every once in a while it will miss and flash the code 41e. Sometimes it will die completely and show codes 41e and 71e. So far it has always started back up. It may run 5 minutes or 4 hours before it acts up again. Any advice would be appreciated.
google the code and the model and you should find it with some digging we had a code come up turned out to be fuel temp sensor it was I think 37E the other option is take code to your deere dealer and if there at all interested in selling you the parts they should look it up for you
Search this forum. The combine forum has a lot of info that is here if you do a search
41e is start signal 71e is diagnostic code stuck high.
I would check the plug at the pump to start. You can unscrew the plug pull back the rubber seals and check. I had a bad wire there on a cts once. What year is your 9500?
