extra fuel capacity on 2366
2300 Views 5 Replies 5 Participants Last post by  8010when
does anyone know of any aftermarket kits for adding extra fuel tank on a 2366 combine?
TIA plowpoint.
I have seen one at a Danish dealer, its called TIEDETANK and holds 135 l
Neighbour mounted a tank on the back platform above the regular tank. Pick up a tank at a tractor wrecker. Just need one that's flat on the bottom.
Prairie Innovations Inc. 1-866-360-6900 in Canada has a tank that mounts under the tin work.. Can not find a web-site but here is a email address [email protected]
Or like the other guy mentioned, a tank from a wrecked truck or something on that order. We used a round tank and got along okay with it.
A 205 l oildrum can do the trick as well. It all depends on how fancy you want to go!!!
But I know the problem, when the fuel is gone the day aint over yet.
We used a tank off of a TD 40 tractor. The issue that we have is that the filler vent on the lower tank is not large enough and when you fill the upper TD40 tank you will think everything is full but if you don't wait it eventually makes its way to the lower tank and you wind up with very little fuel. Anyways good luck, and I know the problem, its very embarrassing to run out when you have an extra fuel tank.
