I'm running a 9500 with a 912 pickup header, and I've always felt the lighting at nite was less than adequate, especially to the sides of the header when turning with the pickup raised at the end of the field. I'm thinking I should mount a couple LED floodlights at the ends of the header ( lots of light with low power draw) aimed fairly close to the front of the machine and out to the sides. Just wondering where there is a good handy spot in the harness to wire to without blowing fuses or limiting power to the existing headlights? I'd like to wire them so they are only on for field lights and not blinding drivers on the road.
