Hi Guys!
Not sure what the issue is, alternator has been replaced as well as the battery.
Will only charge intermittently with little electrical load, switch on the a/c or raise the header. Low voltage alarms, gauge drops to 10-11 volts and stays there.
Will sometimes at random start charging again, usually not though.
Not sure what other components could be causing the issue.
The previous alternator behaved the same way, the repair shop tested it and said it was toasted, not sure if I believe him though as he was keen to sell me a new one.
Grounds are in good condition, help please!
Thanks!
P.S. Its a diesel
Thanks!
P.S. Its a diesel
