1 - 13 of 13 Posts
· Premium Member
I am looking for a few tips from someone with some experience growing fall rye, I have never grown it and would like to try some this year.
What fert rate do guys normally use? Was thinking 70lbs of N split 50/50 ESN and about 40lbs of Phos.
If you graze cattle on there in the fall does it affect winter kill? or reduce yield next year?
I am West of #2 Hwy and would like to seed last week of Aug is there any benefit to seeding earlier? or is there such a thing a too early.
What about weed control? Spray this fall or spring or don't spray at all? Fungicide?
Any advise would be greatly appreciated, Thanks
fall rye
think that much N and that early a seeding in that area will leave you with too much straw/lodge issues next yr - unless you pasture it. Guess this depends bit on variety - I have certified musketeer for sale and know that the case with this variety. A bit of potash not a bad idea. If you seed this early in good conditions you will need very little and cheap weed control - probably bit of 24d in late sept unless winter comes real early.
fall rye
Would seem very hard to winterkill rye even though do think you jumping the gun a bit seeding next wk. Assume some of these early seeders may be dealing with land that hailed out and/or flooded out(did not get seeded in spring)? With this the case would be cautious on amt of N put down with seed for straw/lodging reasons noted before. Guess if you do plant this early think you could cut seeding rate a bit - In any higher rainfall areas with good seeding conditions 1.5b/a lots. If you need seed I have lots in Alberta.
I apply 60lbs of N, 30P, 15K, 8 S. rye is very winter hardy. I grow Hazlet to straight cut it. We haven't grazed it but we do silage it. Hazlet is a semi dwarf if you're worried about straw.
I'd like to see over 50bu/ac but if you don't have early season moisture don't expect too much. Your poorest yields will be on rye stubble. It fits in our rotation, it's not for everyone.
I've grown rye for quite a few years. Not to many acres each year between 70-150, as we only seed it on our worst sandiest land. With rye I get a 45 bu crop, same land durum gets 25. Anyways our last rye crop is in swath and that land is going into grass for a while now.
fall rye yields
In west central ab you should be planning for 60+ net bushels/acre - our afsc 5yr avg is 78.5. However, with these yields do expect/plan for ergot and straight combining is a dream - not reality. Fall rye can not be covered in water for even one wk, but short of standing water it can handle excess moisture likely as good/better than anything else.
fall rye
CU levels .5-1.2ppm(0-6"). Did try some foliar cu snakeoil last yr on some and was not a diff on ergot. Would be curious what method you have tried for increasing cu and what levels you had to get to before noted a diff.
copper won't help with ergot in rye, its seed and pollination is open. i have had good luck with rye in the past few years. i agree it does not like standing water at all. i have also found it will establish in the fall in a saline area but will die in the spring, on my farm rye has the least saline tolerance. i have been using esn and treated urea 50-50 broadcast in fall 100lbs of product each, thinking of trying super u this fall instead. also 100 lbs of s15 and about 25 lbs actual k. seed treated with cruiser max or insure cereal
1 - 13 of 13 Posts
