fan speed actuator 9610
1479 Views 3 Replies 3 Participants Last post by  kris
i cannt get any voltage to the switch on my fan speed button. the fuse is good and has voltage. is there a relay or anything that i could check?? has anyone else had a problem like this??
Here is a 9600 and should be the same, will see tomorrow for a 9610
thanks Tom, Im pretty sure that is the same as on a 10, the wire numbers are the same looks like.
I had a wire break off inside the actuator motor on a 9750 a few years ago all I did was soldier it and has been fine since.
