I have a fixed air foil chaffer I am going to try on my TR70. I noticed last fall I was getting more trash than normal in the grain tank in corn. Checked the fan speed with a mechanical tach and can't get over 900 turned all the way up. Should be able to get at least 1100, correct? I replaced the bottom inside sheave on the fan drive shaft because it was getting loose on the splines and didn't gain much. The primary drive belt is not getting completely to the outer edge of the pulley, what do I need to do to get more travel out of the linkage? I don't really want to put that chaffer in without fixing this first because it probably won't work very well.
I also have a TR86. I noticed the last few years on both machines getting small cob pieces in the corn sample, depends more on corn variety. I've tried every setting imaginable for concave clearance to rotor speed and fan speed, but I imagine it's a threshing issue. Also tried closing the sieves a little, but then too many tailings. I usually run 650 to 750 rotor rpm, and setting 10 to 12 on concaves. Anyone else with advice? Just trying to get the bugs out before they get to the field.
