Sometime you have to wonder what the @$&" they were thinking when they redesign things. The end shields on the last fd70's were awesome compared to the fd75's.Like most things, some things were improved on the 75, such as better drive for hyd pumps, better wear in hinge area. And some things are much poorer on the 75, such as the poor latching of the end shields and the divider points don't come off as easy for winter storage.
+1. I'm not trading my fd70 till they change it back.F**k the European market. I want my hindged shields back
I don't know all of the differences among the years of the FD70's, but I believe 2011 is when they changed how the center draper was attached. I had a 2010, and the center draper section had two chain links on either side of it that went over pegs to "hang" the draper section right behind the cutter bar. In 2011 (?) they changed over to a wishbone piece on either side of the front roller of the center draper. I never saw the update in person, but that is how it I saw it described. Anyways, this was a necessary update because the chain links will eventually wear through, and then the center draper will fold under the header and wreck the adapter. You could get the new style to update the older headers. Assuming the rest of the header looks to be in good shape, I wouldn't be afraid of the 2009 header as long as the update has been done or you can do it.On a FD 70 how about from a 09 to a 11. The 09 I'm looking at is $25,000 less and has a pea auger the 11 doesn't have auger.
I believe from the research I did, and things I read, the change wasn't until 2012. You are also correct that there is an update kit that replaces the chain links. It requires a little bit of welding to do, but the pieces and template come with the kit.I don't know all of the differences among the years of the FD70's, but I believe 2011 is when they changed how the center draper was attached. I had a 2010, and the center draper section had two chain links on either side of it that went over pegs to "hang" the draper section right behind the cutter bar. In 2011 (?) they changed over to a wishbone piece on either side of the front roller of the center draper. I never saw the update in person, but that is how it I saw it described. Anyways, this was a necessary update because the chain links will eventually wear through, and then the center draper will fold under the header and wreck the adapter. You could get the new style to update the older headers. Assuming the rest of the header looks to be in good shape, I wouldn't be afraid of the 2009 header as long as the update has been done or you can do it.
I don't think there is any difference between those. It was in 2012 that MacDon updated the center feed deck frame. It was built heavier and more reinforced. They also changed where the feed deck attached to the header. The got rid of the 2 chain links and went to a different design like the previous post mentioned.On a FD 70 how about from a 09 to a 11. The 09 I'm looking at is $25,000 less and has a pea auger the 11 doesn't have auger.
I have a 2011 2152 (MD) and it had the 2 chainlink design. The chain link pulled out of its weld on the draper section this year. I caught it in time but I lost the rest of the mechanism in the field. My local dealer had the newer style in stock. I didn't pay attention to the change so had to weld twice! The newer attachment requires 3 chain links instead of 2. At least that is the way it worked out. I welded the 2 back in like on the other side, only to have to split a link in the field and weld the additional one on to it to make it longer so the newer "wishbone" one worked!I don't know all of the differences among the years of the FD70's, but I believe 2011 is when they changed how the center draper was attached. I had a 2010, and the center draper section had two chain links on either side of it that went over pegs to "hang" the draper section right behind the cutter bar. In 2011 (?) they changed over to a wishbone piece on either side of the front roller of the center draper. I never saw the update in person, but that is how it I saw it described. Anyways, this was a necessary update because the chain links will eventually wear through, and then the center draper will fold under the header and wreck the adapter. You could get the new style to update the older headers. Assuming the rest of the header looks to be in good shape, I wouldn't be afraid of the 2009 header as long as the update has been done or you can do it.
The newer style gets rid of the chain altogether. There is a kit which comes with the the 2 arms (38 & 39), I'm guessing you currently have, then it comes with the "joint" (37), the triangle lugs (red boxes), and a template for you to weld the lugs on in place of the chain.I have a 2011 2152 (MD) and it had the 2 chainlink design. The chain link pulled out of its weld on the draper section this year. I caught it in time but I lost the rest of the mechanism in the field. My local dealer had the newer style in stock. I didn't pay attention to the change so had to weld twice! The newer attachment requires 3 chain links instead of 2. At least that is the way it worked out. I welded the 2 back in like on the other side, only to have to split a link in the field and weld the additional one on to it to make it longer so the newer "wishbone" one worked!![]()
