Did a bunch of reasearch (neighbors would likely think what is that crazy ******* doing running around cutting already harvested fields?!) yesterday but I can now answer what is happening here.
First, the Captain Obvious stuff using Claas terminology:
Feeder faceplate calibrated (0 to 100 scale, 50 centered)
Header calibrated
The feeder faceplate angle reading should average 50.
Mine didn’t all fall, 35 to 40 ish typical.
Lived with it but my inability to have it run properly pissed me off.
It also doesn’t matter very much when running the header off the ground and on the gauge wheels.
However, running right on the ground cutting very short a different story.
If I run more this fall or on the peas next fall I know I’ll need an on ground, light header.
I like to be as kind to the skid shoes as possible plus greatest rock resistance.
Here what what I ended up doing for those conditions and it needs done in order:
Start on level ground
Oh, make sure transport hitch is installed in field position on wings
Wing flex locked out
Reel in normal operating position
Tilt angle on “A”
Combine feeder faceplate fore/aft at normal
Header just off ground
Gauge wheels lifted all the way up
Feeder faceplate centred
Tightened right springs (evenly) until lifting about 10 pounds on right gauge wheels lifts springs off stop. More on this later.
Set left springs to match, I do it by when lifting header up and having header pop off stops at the same time, let it down full speed and stop before hitting the ground, header should bounce equally off both stops before settling (Claas 700 series has very fast hydraulics for this procedure) Believe it or not 1/2 of one turn on two springs is enough to observe a difference.
This is a far lighter setting than MacDon specs but they sell skidshoes and guards, I buy them.
Unlock wing flex, hit the field
Adjust wings until lateral tilt averages centered, 50 in a Claas case.
The wings will then average straight left and right on the indicators.
Again, this is on ground setting, float springs would have to be backed off for proper on gauge wheel operation. At least once flex is set it’s set.
This two sensor system has shown us how much better float and flex settings can be achieved than the manual system, if just points out our flawed setting.
