1 - 9 of 9 Posts
while flexing soys it seems like my left wing doesn't frown when it should.it seems to stick a little higher than it should, when I get to the end of the round and lift, it will frown then, what could be sticking?,thanks
Check the vertical rods under them plastic covers under the bell cranks. They have rubber bushings in them and go bad and can make the wings sticky. The new FD75 have an eyelets now instead of the rubber bushings. You can change over to this. I did this to one of ours and am waiting to try it out. My right wing was sticking last year and I had to keep adjusting the balance of that side to get it to frown. Good luck
thanks ,I'll check this too.
I need help with 30' MacDon FD75 this is our second year with it and no-one seems able to adjust it to stop it from cutting high in uneven ground mainly the wings I am being outcut by a john deere 625f and Lexion 25' auger headers. I am usually slugged in front of feeder chain in draper auger It is on Lexion 585R soybeans are making 68 to 80 bpa trying to trade for Lexion 30' auger header but finding out MacDon overpriced only when you buy it no dummy this my 37th year and am miserable
Your spring tension is to high. Does it frown when it is up in the air? Dealer needs to get out there and adjust it properly. May have to contact Macdon if your dealer is not assisting you. That head should cut circles around the others. You could not pay me enough to go back to an auger head.
frowns
just a slight frown sometimes last guy screwed wing tension bolts within an inch and half of end of travel then it plugged on ends wing s will not go down quickly after dips or bumps I told boys everyone likes these things but they are sick of seeing me stopped constantly also slugged lexion twice already and that tends to tick everyone off!
1 - 9 of 9 Posts
