We have a r75 that did have a field star 1 monitor but the screen quit working and were told it couldn't be fixed. Was wondering if anyone had a used one kicking around that they are not using. Or where we could find one.
There is a Reman screen option through AGCO which cuts the price a fair bit .
Can't remember exactly the dollar amount but it was substantially cheaper than new.
Ours worked perfectly and than one day it would not turn on .
AGCO has a voltage and continuity test procedure to pin point it down to the screen and eliminateing the wiring as a cause .
if you cant find one and upgrade the system, I am interested in the yield sensor, I have called several salvage yards, and no luck. I sent it to microtrak and they said it was bad, needing replaced
opeeman1
I have an old gleaner yield sensor that has fingers that stick down into the grain flow.
It was working when gleaner put a test model on.
785 632 1667
