Been fighting a power issue on my 93 r52 with the deutz. It will run fine for 2-3 hours and then get doggy (along with an rpm drop). Here's what I've done so far -- I've fought this for a few years. Replaced both rubber lines to the lift pump. Replaced the lift pump -- this helped as I was getting air into my filters -- after replacement I no longer have the air. Cleaned screen in fuel tank, cleaned fuel tank.
Basically I start off running 2700 rpms no load -- going thru the field it'll push 2650-2640, after about an hour to 45 min this drops to 2620-2580 - still works ok but starting to get weak. The longer I run the slower my rpms get and the less response I have from the governor to load. This also corresponds with it wanting to rev more if I remove the load. ex shut off seperator and no load on hydro and the engine will rev to 3000 rpms. Starting to think the pump. Really chasing my tail as everytime I restart its ok -- so I put in new air cleaners -- seemed to work for a few hours, fuel filters, same deal. Any ideas?
