Hi. Looking for some help on our air cart. It's a variable rate 3450. Has been working really well last few years but has started acting up as of late. Was seeding peas the other day out of the rear tank and near the end of the day the meter roller started acting up. Monitor would say tank 3 is shorted or open and rate would go to zero. Id turn out and wait a bit then it'd work fine for a bit then the same problem would happen. It's pretty frusturating to say the least. Managed to finish the field and pulled roller out all bearings seemed fine as I thought maybe that could be the problem. It seems maybe it's an electrical problem but not to sure. We changed the shaft speed sensor this morning but haven't tried it out yet. I thought maybe it was the tank 3 switch on the tank but I switched tank 3 to run off tank 1 switch and it still acted up the other day. No great service support on these tanks it seems the service guys don't know much about them. Any one ever run into this issue? Any help would be greatly appreciated. Thanks
