Does anyone have any advice on how to remove and replace the bushings circled in the pictures attached here without disassembling the entire drill?
Automotive tire Motor vehicle Glove Bumper Vehicle
Tire Wheel Automotive tire Tread Synthetic rubber
That’s a good question. I would venture to guess most would sell drill or park it if it was too wore out.
Is it the bushing? Or is the hole in the side plates that are egged out? If it is the plates I would get some bushings and longer pins. I did this to the axle pivots on my Kello disc, I cut the plates out to fit the bushings, assembled it all and welded the bushings to the plate. It will last way longer than original.
I have never paid attention to that bushing. I assume it is sloppy. Let us know what you come up with to fix it. I am amazed at how many acres these 5000 drills do with not much maintenance.
