Where is the float sensor on a 2388. Where can i find a scematic wiring diagram on 03 2388
D dustfarm · Registered Joined Oct 5, 2008 · 22 Posts Discussion Starter • #1 • Oct 25, 2008 Where is the float sensor on a 2388. Where can i find a scematic wiring diagram on 03 2388
A amax · Premium Member Joined Jun 23, 2008 · 385 Posts #2 • Oct 25, 2008 Float sensor should be in the line between the lift cyl. I have a schematic in my cnh school book but don't know how to send you a copy. Maxie
D dustfarm · Registered Joined Oct 5, 2008 · 22 Posts Discussion Starter • #3 • Oct 25, 2008 where at?
S striker782 · Registered Joined May 20, 2005 · 193 Posts #4 • Oct 25, 2008 Follow the hoses up above the axle and you will see a steel block where the hoses attach. The float sensor is screwed into the block.
D dustfarm · Registered Joined Oct 5, 2008 · 22 Posts Discussion Starter • #5 • Oct 25, 2008 Is there anywhere online, to find service manuals or diagrams for free. So I could see the float sensor
P pureel · Registered Joined Jan 30, 2006 · 363 Posts #6 • Oct 26, 2008 Try searching the parts online https://webparts.pvassociates.net/cnh/webparts/main.php
