After some help or advice in why my VR application is way off the mark insofar as the actual applied rate.
VR plan was done in farmworks & all seemed to fine.
Imported the plan in shape file format to FM1000, selected as "applied rate" - all seemed fine.
However, the actual applied rate was way over the design rate. The flow meter calibration has not changed & was spot on previously doing spraying without VR.
The logic gives me a headache in this but I note a "prescription scale factor". Why would you need to scale an already worked out prescription application file ..... again, after it has been calculated to an enth of its life via a computer program that is designed to do .... just this very thing?
