1 - 2 of 2 Posts
Im selling a Victory Electrostatic Cordless Sprayer in excellent condition, it includes extra tand and extra battery, (2 tanks and 2 batteries), wrench, case and extra accessories,it was used about 4 times.
Double-charged particles envelope all conductive surfaces – shadowed, vertical and underneath.Coats up to 2,800 square feet on a single tank of fluid. Combined with our patented electrostatic charge, this allows you to apply an even coating on all surfaces.
Applies chemicals faster
Uses less solution
More complete and consistent coverage.
KEY FEATURES
Patented electrostatic charge penetrates chemical providing a thin even spray pattern on all surfaces
Weighs only 5.9 lbs. with a full tank
Cordless convenience allows for effortless movement room to room
3-in-1 nozzle lets you set the spray particle size to match your application
Easy Fill HDPE 33.8oz refillable tank allows you coat up to 2800 sq. ft. on 40 micron setting
Victory 16.8V Lithium-Ion battery allows you to run between 20-80 tanks on a single charge
SPECIFICATIONS
Voltage16.8VWarranty1yr limited warrantyBattery16.8V 3400mAh Lithium-IonWeight3.8 lbs. (5.9 lbs. full)LED LightYesOptimum Spray Distance2 – 3ftTank Capacity33.8 oz.Run Time4 hoursNozzle Spray Sizes40 micron full cone, 80 micron full cone, 110 micron 120° fanCharge Time90 MinutesFlow Rate40 micron / 3.1 oz per minute 80 micron / 3.8 oz. per minute 110 micron / 10.5 oz. per minute
Asking for $7500
Pm me for any questions and inquiries.
158768
Uses less solution
KEY FEATURES
SPECIFICATIONS
Asking for $7500
Hello i am interested is this still available?
1 - 2 of 2 Posts
