It has AIM Command on it
Im told its been on the machines for around 10 years or so...
Im guessing in that time theyve surely gotten things figured out
This machine is a few years old... Has 800 hours and sounds like its in good shape
What have you guys heard about this AIM system
I think if it works good id love it...
Also thank you to the other guys who responded back to my post earlier.
I know this is a harvest website but When its not that time of the year its very helpful to have a place where there are just CASE IH guys (for the most part) and i can get info about other things...
So thank you.
no feel free to talk about anything you want.... I just didn't want to make it like the news talk ag forums.... but I hope its the second best thing
Casefarmer I bought a new 4410 last year with aim command on it.It does keep the same micron size and pressure at the tip from 2 mph to 20mph That is nice for slowing down to turn or waterways. The aim has insist on off I think it has better coverage because your pressure is constant the faster you go the droplet size remains constant it does't turn to a fine mist with higher pressure as you go faster. Aim also allows you 2 settings so your first pass around the outside you can run larger droplets then switch to 2nd setting for rest of field I think the aim command on the sprayer would be a good selling point On our new one it was a 12000$ option Hope this helps a little.
Thats a cool website
Glad they like the case planter and the kabota Utility Vehicle and Zero Turn mower
we have all three and
That Utility vehicle is by far the best in class
And that mower is a hoss....with that disel engine
8010 Farmer Thanks!!!!!!!!!!!!!!!!!!!!!!!!!
Also holy crap thats alot of money for the option
I really like the idea of being able to spray say...10gpa at 2-whatever MPH
Alot of times in situations i had to keep my speed up to make sure it sprayed like it should and i hated that cause usually it followed with a bang or thud.
and im very careful especially when im spray for someone else commercialy i try to take my time and really do the best job possible
This should work out good for me
im glad youve had good luck with it
The only thing my case sprayer salesman has talked about were the poppers on the systems had been updated to a newer style that i won't have to replace often
i guess on the old style it was a 2 year and change them out type of deal
(beats me)
Thanks again
