deere released a pip in oct. on any machine with the "High Torque Variable feederhouse drive installed" wether it was factory installed or field installed it needs to have additional welds and gussets added to the reverser mounts. even some of the machines that are part of this pip, don't get all the welds that they need. so if you have this reverser and didn't get added gussets, i suggest you check it out, because these cracks and breaks are easy to miss with the reverser installed. here are some pics of what is the usual failure, however this is not the only way they fail. just a little info to possibly prevent a major break down in the heat of everything
i'm sure everyone is getting that harvest itch, i know i am. so i guess this gives you an excuse to go out and visit your machine
from the inside
from the inside
