Here's the deal. This combination having trouble getting canola to rotor in many conditions. Thinking it was in feeder we did some modifing that only made sense and yes we made some great strides forward that will only make feeder more forgiving no matter the crop or header. Ends up the feeder again was not the major problem. Just like we fight with jobber heads feeding the feeder wrong the 4200 built by MacDon was also doing so. We first narrowed opening to prevent material from getting behind feeder slats witch is good. We then added flighing to bring material in well beyond sides of feeder witch is very good. Next we Noticed the auger drum would bang up and down. This would slug the auger and or the feed chain. This could be heard threwout the machine all day. While watching movement of rear feed drum with camara we could see drum run on the bottom most of the time other than when slug come from swath or header auger creating the slug. Long and short of it is get the extra flighting on auger and raise the auger as far as you can. Better yet would be get some good shocks fasten to the drum to stabilize the movement. It was always great to add the flighting to the old Gleaner heads as it was good idea to raise the ridged auger up for Canola.Adding shocks will have same affect as adding the shocks to tension drums and that was a huge step in right direction for the feeders.
Also noticed auger appeared to be turning to fast. Knowing this head sold to other manufactures That have slower drive shaft to drive header I got to thinking weather they had a sprocker fastened to Gleaner application to slow it back down. I don't know the count of teeth on the other brands but see in AGCO parts there is a 13 tooth available to slow it down. Did not get chance to try one prior to Canola harvest done but I sure will sometime
