1 - 2 of 2 Posts
I have a Series 3 head that I am running on a F2 combine. I wired a reverse polarity switch and am feeding 12 volts to the reel motor but not seeing a reel speed change.
Looking at a R60 wiring schematic I think the motor should be powered by 12 volts? Is this right or does it need a resistor in the circuit?
Is there an aftermarket to purchase a motor versus dealer?
Make sure you have both the 12V & a chassis ground available to your reversing switch. No resistor needed. 2 wires to the motor, 12V & ground one way to move the motor, flip to move the other.
1 - 2 of 2 Posts
