Fair call but where do you buy a reliable grader for 10-15K????? Seem to have to start at 30K to get anything half decent, even then they are kinda like dinosaurs. I`m wanting a heavy duty blade that can go behind a 100-200 hp tractor. Not necessarily needing the power but just want one that is rated to handle the HP so it should be well built. ThanksX2 just buy a grader, the collier and miller trailing graders are built well but hydraulic bypass in the rams buggers any ability to hold any position in tough going.
Far better and more control with a normal grader.
Who makes that blade?? what`s the cost to buy??Something like this or bigger?? If you want bigger PJ9510 is a forum member on here with a real nice grader blade he built for sale. Suit 200-300hp. He has a thread about it on here somewhere.
Found iyt on farmmachinery.com but price seems a bit high. Not sayin id didn`t cost that much to build but can probly find reasonable complete grader going for that price. My price range is 20k Max.Found PJ's beast. Don't be afraid of freight for anything down south Fonz. It's quite ridiculous how cheap you can get stuff moved from any part of the country useing loadshift.com.au. You basically tell them what you want to pay in the end.
Fonzy. You`ll get a Grizzly engineering blade for around $10,000. There will be a dealer near you.Found iyt on farmmachinery.com but price seems a bit high. Not sayin id didn`t cost that much to build but can probly find reasonable complete grader going for that price. My price range is 20k Max.
Our local engineering shop make good strong gear. 10' and 12' options for around $14 and $15k plus g spot. They are up at AGQUIP fonz so you may be Able to get a bargain.Who makes that blade?? what`s the cost to buy??
