1 - 10 of 10 Posts
Anyone running the Goodyear LSW tires on a sprayer? If so how do you like them and would they be better than trelleborgs?
I am running trelleborg 710/46s on my SP400F. They work very well. Goodyear makes same size and dubs it LSW but not an IF type tire. I have had very poor luck with Goodyear ag tires over the years, so was pretty leary to purchase another set when the trelleborgs were damm near $900 a tire less money and are an IF type tire.
Discussion Starter #3
I had 710 trelleborg on my last sprayer but this time they recommended the goodyear lsw
, not sure what I should do.
Discussion Starter #5
No they never gave a reason to switch , other than they recommend them.
Im running IF800/55R46 LSW on my NH sprayer, no complaints. The large rim size keeps the offset from sticking out too far.
The second number is the sidewall ratio to tire width. So 800/55 means your sidewall is 800mm x .55 = 440mm So unloaded diameter is 440 x 2 + 46 x 25.4 = 2048.4mm or 80.6 in. In theory
1 - 10 of 10 Posts
