I have no idea why people insist on quick fixes for this problem. If you rivet them in, or screw or bolt or whatever, you end up with a place for moisture and fine dirt to accumulate, rusting out whats left of the original trough. Welding them in is in my opinion the only way to go. Of course then you'd be limited to using mild steel ones, like the ones that hoxie implement sells.
