21 - 40 of 126 Posts
In my opinion, all grease guns and grease gun ends suck. We've started buying the cheapest ones we can find. They work about as long as the expensive ones and it doesn't hurt the pocket book so bad when you throw the cheap ones away and buy a new one.
If someone ever comes out with a grease gun that actually works and last, they will have a million dollar business and won't be able to keep up with production.
Buy some Swiss or German ones. The one that came with our Claas works very well. I cannot remember the swiss brand that was supposed to be good. Google may be your friend on that one.
Try the "Alemite" brand. Priced about the same as a Lincoln. All of my Lincoln's would bypass the grease past the plunger if left on the rack for a week. You go to use it and think its empty except all the grease is on the wrong side of the plunger. Last time it did that it 'slipped' out of my hand and broke when it hit the floor. Spent more money on wasted grease than the gun was worth. Wouldnt use a Lincoln again if it was free.
I have had good luck with the Alemite's - I bought two of them five years ago and no problems. I bought mine because my father in law has a couple that are 15+ years old and still working good.
I was struggling again this fall with grease gun ends. The particular gun in my hands at the time and on a certain zerk and was puking out grease ( no damage on the zerk ) so I spun on a new end and so started the episode of the new one sticking onto the zerk so bad I just about broke it trying to get it off and then the brand new grease gun end wouldn't work as it puked out its guts ( it had a rubber internal seal ). Finally I had gone through my bag of gun ends and the whole batch was garbage and left me thinking back to this thread from last winter.
So it refreshed me that the name Alemite stood out as better then Lincoln and I did a search of the company and finally came up with a list of ends and to my surprise it does list more then one style as having the rubber seal and I will include the link to the page I was looking at.
Couplers - Hydraulic - Alemite
So my question is, does anyone know who handles Alemite in Alberta as I seem to run into ether Lincoln or some no name crap that is even worse. Or for that matter run across grease gun ends that are even better ?
Same problem here, I would really like to try some out. Maybe I'll steal a couple from new grease guns in the store :rolleyes:. Why do they sell whole guns and not the couplers :confused:.
I bought some John Deere couplers the other day, they don't leak but one seems to have fallen apart already. I got both standard and heavy duty, so far it's the heavy duty one that's fallen apart. They have a four section jaw.
Good to hear I am not the only one having this problem. Been using Lincoln here for years but once a new one gets 6 months on it they p...s all the grease out past the plunger. Got sick of them so tryed JD they last even less, dad got so angrey he turned a plunger up & made an O ring to suit, now NO grease gets past that! Some one said they changed the make up of the rubber a few years back, & thats when our trouble started.
Have not come up with an end worthy of naming tho..
I was trying to find a supplier of Alemite for western Canada and just now found a dealer locator section and wrote a note to a rep. I guess I'll see if its replied to at some point and see who they sell them through and if there is a dealer up in the north west part of Alberta.
Lincoln are garbage. I just picked up a four piece end one from john Deere I was going to try but my grease gun got ran over by the grain cart yesterday.
Try a grease gun end from Wurth. I have found them to be very good.
Problem with that is then you get the Wurth rep dropping by every week and you'll feel real guilty not buying more when they give you the Wurth calender :eek:
I just bought a CaseIH pistol type gun this fall because I needed one and was at the dealer. So far quite impressed with it, seems to stay on the fitting without being held and doesn't leak.
I've only used it for a couple of months but for $30-35 cost it's worth a shot.;)
Part #MC5403: Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts :: Heavy Duty Pistol Grip Grease Gun W/18"Hos
Two seasons on a cordless Milwaukee. Everything about it is quality including the tip. Got it online from Northern Tools.
I finally tracked down a few local outlets to buy Alemite products from, in Grande Prairie Alberta to be specific and will paste in the reply letter the Alemite rep was kind enough to send back. Only Greggs happened to stock anything but any of them can order it in from Edmonton. I haven't tried them and not much equipment greasing happens here during the winter so it will be a next season thing to get an idea of what I think of them. I was after the rubber seal style and bought # 308730 and diameter wise it looks the same as the Lincoln ends. Then I picked up just one of the 6304-B ends and was shocked to see how large in diameter it is but perhaps there is a reason for that although it would not be the end to use in small U joints as I can hardly get a so called narrow tip onto the grease zerk as it is. The packaging says they are made in China but that doesn't mean they are bad ... time will tell.
Speaking of Lincoln, I didn't know what part number of end came on grease guns I've bought but have tried using a gun end model 5852 which comes in a bubble wrap package of 1 and it seemed to work ok but won't seal on some zerks. Its supposed to be of better quality then the bulk ends Loncoln sells but still is only rated for 6000 psi pressure.
I did find out what brand of end I had been trying to use that has the rubber insert and how crappy an end they are, it was Dynaline and the four jaw style. Now they exemplify the garbage that "can" come out of China and hardly worth the effort to buy even though they are far cheaper then other ends.
Good day,
Our coupler model # 308730 narrow and (308730-A narrow with check valve), would be the number you are looking for. Both have a rubber seal. We also have a standard or heavier model, (larger in size) number 6304-B and (6304-C with check valve), these have a metal seal, they are both rated at 10,000 psi. We also have a number of different models button head, pin type etc. As for distributors in Grande Prairie, Resource Purchasing, Gregg Distributors, Red L Distributors. I see you have issues with getting off the zerk, I can only assume you use a rolling type action to fit on to and take off coupler. The jaws on the coupler should release much easier. Of course they may be times when they do pressure seal on, more so with use with a battery operated gun. Never pull directly of as this wears jaws and may break fitting.
thank you, Terry
