Hi all! Getting ready to use the old JD brown box but I’m having some issues. Had to put a newer 3000 glove on it and I can’t turn on tracking! I just updated the system, checked frequency, turned SF1 on and off, but no luck. Been fiddling with it for an hour now with no luck. It does have the proper key card also. Any help would be greatly appreciated!
Murray try it the next day. I had the exact same problem. I would also perform a tcm calibration. Go to settings and differential set up. You can choose sf1, waas, or a demo period of sf2. The three thousand receiver must need a period of time to hook up to satellites. The next day my brown box was working fine.
Is your 3000 running 2.80S software? If it isn't its not going to pick up new signal frequency. Also check to make sure you are running on DEFAULT frequency and not the BELOW that is in the BB for the 3000. Hope this helps.
