Just wondered if there were any hardi gurus out there that could help me with a problem on our commander 6036 s trailed sprayer.
It's a little hard to explain....
For some reason when folding or unfolding the boom arms you have to push the tractor hydraulics different ways when using the hardi's electronic switches.
Normally you would just push the hydraulic spool valve in the tractor forward and forget about it and just use the hardi's control box to tilt the wings and fold each section, now you have to reverse the flow to move certain sections and the direction of the switches are also reversed.
Nothing has changed in terms of moving any hydraulic pipes. It is not the tractor as have tried swapping them over. Is there some kind of valve that automatically changes the flow when opening or closing various rams that might be stuck or something?
Any help would be much appreciated.
