Need to know were do you start with greenstar in a secondhand 9660 STS
Owner used it and we took it over with the combine
Cleared the PC Data storage card and key card
Am new to greenstar but want to use it to it's fullest
Thanks
Thanks for the response,just the data card was cleared by the owner not the keycard
Registered at Stellarsupport,were are the serial nr of the receiver and the greenstar (brown) original be found.
Need that info to transfer it to my name
Thanks
Solly
If you cleared your keycard, you might be in trouble - you'll have to send it back into Deere with the original order #'s to get the software re-activated. That was as of a year or so ago, they might have a better process by now. The keycard only holds the Harvest Doc software, no data, so the only time it needs to come out is to run updates.
The best way to get started with it is to get a copy of Apex or third-party desktop software, then enter all your crops, field names, and equipment to the card before you go to the field. Saves a ton of time and confusion.
The SN can be found on the back of the display for the brown box and you can look in info then display and page to it and the receiver is info Starfire receiver, then page to the SN
