1 - 12 of 12 Posts
Harvest is in full swing. Here is a small sampling of Ekotuning activity in the past few weeks.
This JD 9770 in SK received a +50hp Ekotune . While the 9.0 engine is at the top of it's series for the engine family, our extensive data logging shows it to have room for a +50hp increase. Many other chips and tuners will claim +25% but that's not feasible for engine longevity. In fact this one had a chip.
Massey Ferguson with C13 engine running a +50hp Ekotune. Keeping it safe at 475hp. Thanks to Bentz Ag Tuning out of Southey SK for these photos.
Some spray work also going on. This Apache with a 6.7 Cummins was lifted by +60hp. Thank you Lewis Nolt, our dealer in PA for the photo.
JD S670 in Alberta with a +50hp Ekotune. Once again the 9.0 engine very similar to the 9770 except with DPF, or DPF and SCR in the latest generation. Poor quality tuning will result in excessive DPF regens and depleted DPF life span but because the DPF captures particulate matter, it's nearly impossible to notice a sub standard tune. Tier 3 machines without DPF will reveal bad tuning. Many first gen S670 customers were not happy when trading from a 9770 but we have the correct medicine.
Another S670 photo sent by our customer in Indiana.
Lexion 780 in SK with a Mercedes Benz V8.
JD 9410R with 13.5 engine - These machines run so nice with a +50 to +100 hp Ekotune. The engine is good for 600hp but driveline will be limiting factor. With over 10 years of experience with Ag machinery tuning we are well informed to give you solid advice and consultation. Thanks T.Christie Performance for this photo.
Case 8230 - The FPT 12.9 engine factory set at 450hp (510hp peak) can well handle a +50hp bringing it to 9230 specs.
Ekotuning thanks all of our loyal customers who are helping us grow. Word of mouth advertising is the best kind.
Have a great weekend!
Discussion Starter #4
We have 3 dealers in Alberta.
While we do not yet have an Idaho location, we can still serve customers in areas where we do not have a dealer by using our hand-held programmer option. We simply ship you an end user programmer which is capable of storing the factory engine tune as well as the Ekotune. The programmer supports most modern Ag machines.
EkotuningCom tuning, chipping, programming, remapping
Discussion Starter #7
The PS transmission part number in a 410R matches to the 9460R. The 510 and 560R have matching reman numbers. Depending on the application, a 100hp tune may not be recommended in a 410 due to driveline limitations.
Discussion Starter #12
How much can you tune a 1998 9300, 24 spd? Weighs 37000, 710x38. I guess virtually NO emissions on it, smokeless, but full of NOX.
Late model 9300's using a Phoenix engine controller can be Ekotuned with a recommended +50hp tune bringing it to 9400 specs. Earlier serial number tractors have a bosch or lucas controller which we cannot tune.
If your tractor has a 9 pin Deutch diagnostic connector in the cab by the 12 volt cigarette plug then most likely it uses the Phoenix controller.
1 - 12 of 12 Posts
