I took a few snaps earlier this week.
Earlier in the week wind flattened a lot of standing corn, like this. The 2206 head will pick it up but it isn't pretty.
Edit: Fixored the URLs from \ to /. -Lance
Sorry mate - links are no good...
- Peter
Works for me now aswell!
Very nice pics you posted there computerguy
- Peter
Firefox showed nothing for me, but IE worked fine. I found the URLs to have the wrong slash in them, which is fixed now.
That flat corn stuff sure makes for a long day, doesn't it. We found that if you lower the snoots down all the way it does seem to work better, and keeps the row units up away from the dirt a bit more. We dropped the pins to the lowest hole, then lowered the bolts as far as they would go too. Set your end snoots, then one-by-one set the center ones. Make sure the tips are all level, maybe the outside ones a bit higher than the rest. This is what worked for us, so maybe it will work for you too.
-Lance
That's exactly what we did mx270a. And the corn feeds much better as a result. It's miserable going no matter what you do.
