1 - 12 of 12 Posts
These are some pictures I took of the wheat harvest in Western Kentucky. Wheat is harvested in WKY in mid-June and soybeans are double cropped in right behind the combines.
6 9860 STS combines opening up a field
New Bullet Rotor 9860 STS
Tight Turn
Cutting Wheat
Doubling Cropping Beans with a 9520 and 9620T on 60f Horsch Anderson Air Drills.
Storm on the way
Wind Picking Up
Starting to rain
Thunderstorm hits
Rained out for the day
You can see video of these pictures at http://toytractortimes.com/july06/
That Challenger is a horse! Look at its frame compared to the 9x20T, as well as its undercarriage. Obviously built more stout and powerfu, even if it has less horsepower. Comparing the two engines, the mid-sized Challenger has a 30% larger engine that the largest 9620T. More displacement = pulling power and better fuel economy because its optimized vs. being maximized in the Deere engine.
Quote:Does anyone know what kind of drill they are useing?
The air drills being used are HORSCH ANDERSON. You can see their website at http://www.horschanderson.com/equipment.htm
They are impressive drills. The Horsch Anderson drills used by this farm a 60ft models. They kind of plant like the Concord drill planting the rows in a ribon with two row close and then a small divde and another two close rows.
For the beans they work right through the heavy straw.
Discussion Starter · #12 ·
Quote:How many acres do you guys farm in Kentucky?
Other than the 9650 pictured the other wheat pictures are from Garnett Farms in Hopkinsville, KY. They plant 6,000 acres of wheat that is double cropped into 6,000 acres of soybeans. Wheat is harvested in mid June and soybeans are harvested in late October.
They also plant just over 10,000 acres of corn. I will post some corn shelling pictures from the farm.
I saw a post about tobacco above. Garnett Farms also plant around 200 acres of tobacco.
1 - 12 of 12 Posts
