We drilled some wheat on a dry land field and also have a field that we drilled wheat in strips to relay soybeans into in the spring. Will only have around 100 acres of wheat to cut. was hoping we could leave our roundbar concaves in and put a filler plate or insert into the front sections. Has anyone had luck doing this?
You should get by just fine with the filler plates. If you were doing more acres I would say you would want to change the front concaves.
