1 - 9 of 9 Posts
Put a 1010 header on my old IH 1480, has anyone upgraded their hydraulics for the for and aft feature that a 1480 does not have?. I was wondering if a 1680 hydraulic section would be able to be added to valve stack and use hydraulic hoses from there.
We had the extra valve on our machine but had a problem with our valve and replaced it with one off a 16oo series. We also added a valve for field tracker. Is your machine electric over hyd. If it is you have to wire your cellinoids so that you activate the jammer valve to build pressure in the valve stack
The jammer valve is on the bottom of the valve stack if you use a test light it is the only cellenoid that will be hot for every function on the valve. What it does is it blocks oil flow to build pressure when you activate a function
1 - 9 of 9 Posts
