1 - 14 of 14 Posts
Ive got a 89 1660 and im running a 1020 17.5 head. Its got the poly slides on the bottom and the 3 inch cut case cutter bar. Im having problems with it wanting to dig in the ground at times like the automatic float stops working.and it likes to push the top layer of dirt instead of slide over it. Im always having to stop and back up. another thing it does is if you come to the top of a hill the head won't got down. It's like the floating system gets lost and don't know what to do. Then as soon as the head hits the ground again it starts floating again.
Been a bit for me in a 1660, but can't you fiddle with the sensitivity and response of the header? Also mine was acting goofy and had to replace the connecting plugs on the base unit and header, can't remember for sure but I think mine was "flopping" for lack of better term.
· Premium Member
This wouldn't have anything to do with the head not floating right at the top of a hill but early beans tend to drag more than they will in a few more weeks ! Has this head been used successfully in the past on this combine?
Yeah it worked fine last year.
This year im having to hit the down button all the time. Everything is moving freely as far as the sensor and the bar that goes across the bottom. One other thing I forgot to mention. In the past all I had top do to lower the head all the way down was hit the down button for just a second and it would drop the rest of the way on it's own. This year I have to hold it down the whole way or it stops.
Just wondering if this is going to be my problem down the road when we start in the beans . I've got some weird problem with the return to cut right now it won't always work with changing headers . Works somewhat with the 1020 being a low number on the height meter but put the pickup header and with 30+ numbers and when you adjust the height knob to that height and you get the double arrow the header raises up a foot or more and adjusting the height knob down doesn't doo nothing .
Discussion Starter · #10 ·
I put a new sensor of the head and it seems to be doing ok.
Next problem I have is the reel speed when switched into automatic mode it goes wide open wether im moving or not.
What would cause this? It works fine in manual mode.
1 - 14 of 14 Posts
